Max freq for gpio toggling & wait state in lpc1317
353 次查看
lpcware
Content originally posted in LPCWare by aamir ali on Fri May 03 09:04:41 MST 2013
I am running lpc1317 with 72mhz.
1. Gpio peripheral can also be clocked to 72 mhz as AHB & APB are at same 72Mhz.
Now at what max speed I can toggle GPIO. Is it 72 Mhz?
2. What is wait state for reading flash at 72MHZ.
341 次查看
lpcware
Content originally posted in LPCWare by vasanth on Sun May 05 01:12:53 MST 2013
Toggling a pin at 72Mhz will always be measured in frequency as 36Mhz.
(Freq = 1 / (Ton + Toff)).
For more info, take a look at this long and interesting thread.
http://knowledgebase.nxp.com/showthread.php?t=1832
341 次查看
lpcware
Content originally posted in LPCWare by aamir ali on Fri May 03 10:31:47 MST 2013
how did you calculate 36mhz. both apb & ahb are at 72
341 次查看
lpcware
Content originally posted in LPCWare by R2D2 on Fri May 03 09:38:13 MST 2013
No, 36 MHz.
UM: 72 MHz Flash memory access time: 3 system clocks
