Content originally posted in LPCWare by jab on Thu Nov 03 12:27:08 MST 2011
I wanted to know fit here is a way to tell the compiler to not to use a section of memory in the microcontroller.
Say for example I wanted to build a dynamically growing software stack, so i mark off 10k of memory which i can have a pointer to the base address and a pointer to the top of the stack.
How can i tell the compiler not to put any variables in that space, either marking it as do not use or fooling the compiler into thinking it doesnt exist.
Julian
