Content originally posted in LPCWare by lneumann on Sun Oct 20 12:03:46 MST 2013
Hello
Thanks for your fast answer, even on Sunday.
Well, first it didn't worked with your solution. I checked the write protection of the folder, set it to non-protected. When I restarted LPCXpresso 6, I tried to reenter the activation code. The code got accepted, I restarted LPCXpresso 6 and again: Error=4, 8k limit!
Then I closed LPCXpresso again and DELETED the folder "NXPLPCXpresso" in the WinXP directory. I restarted LPCXpresso and what I see? 8k limit, but this time with Error=1. Again, I put in the activation code, restarted LPCXpresso and there we are, now it's activated!
Thanks for help. Hope you can use my short report.
Leander
