Content originally posted in LPCWare by Ex-Zero on Tue Nov 30 15:23:23 MST 2010
@KTownsend:
Wow, LPCXpresso MVP !!! Dreaming of this since 20 years Embedded Systems.
Does it include a certificate, a cup or a ring? Or some power of order?
Is this MVP allowed to command a platoon of LPCXpresso recruits, shout at them and let them... hmmm... solder a LQFP200 with an old 300W soldering gun?
All my dreams come true, someone somewhere names me somehow.
@sreynoso:
If you use a breakpoint in your timer interrupt and also in your adc interrupt you can control if your timer and adc is working as expected.
If you don't config the right external match bit, you'll just see your timer interrupt working and no adc interrupt (believe me, I've tried it).
