Content originally posted in LPCWare by nsdesai on Mon Oct 20 13:50:35 MST 2014Hi, I am trying to use the auto-baud feature in LPC1115. I set the bits in the UART ACR register and in the ISR, I verified that the end of auto-baud flag is set. I clear the auto-baud interrupt in the ISR and then try to send messages using UARTSend from the main loop. But, after it comes out of the ISR, it does not start executing from the point where it was interrupted. Can anyone help me with this? I have attached the code with this post.Note: I did enable the interrupts in the UARTInit function even though the attached code shows them commented out.Thanks,Neel.Original Attachment has been moved to: uart_0.c.zip
Original Attachment has been moved to: main_10.c.zip
Original Attachment has been moved to: uart_0.h.zip
