Help on programming...
344件の閲覧回数
lpcware
Content originally posted in LPCWare by raghavendrabsrg on Tue Nov 01 05:44:54 MST 2011
Hi, Im a beginner in LPC and desperately need your help guys.
I've to make a simple robot for a competition (with NO prize money), deadline is 3days.
Now I've written a simple algorithm of how the bot works, And its running pretty with an AVR 128(atmel).
But im not able to startup good with LPCxpresso 1114/302...
So i actually needed some real code that works.. if you can help, i'd be greatful to you...
Algorithm -
Objective: The robot must find its enemy bot, and then push the enemy bot out of the arena which is a circle of black line.
To find black line and to be inside the circle i've used line sensors.
To find the enemy bot i've used a obstacle sensor.
S1 is a left side line sensor.
s2 is a right side line sensor.
A1 is a obstacle sensor at front of the bot.
//program begins
#includes ??
main()   // main program begins
while(1)   // let the main program run forever in the MCU.
If((s1||s2) == 0)  // bot is inside the circle, so search the target.
Searchmode();
If(s1 == 1)  // line detected, so turn back into the circle, and search again.
turn right for 0.5 seconds;
go front for 1 second;
searchmode();
If(s2 == 1)  // line detected, so turn back into the circle, and search again.
turn left for 0.5 seconds;
searchmode();
}  // end while.
}  // end Main.
Searchmode()  // begin search sub program.
Rotate bot, searching for a signal in obstacle sensor - for 3 seconds;
If (A1 == 1)  // bot found!, so stop, and move towards the bot and push it.
stop;
move forward;
else  // bot escaped, so move forward and search again.
Move forward 1 second and again search mode();
// End of everything.
And i know this is not fair to ask the actual code, but i was not satisfied with the stuff i found in the 'examples' given.. so need to get familiarized with those GPIOSetValue(para) and other basic stuff..
thanks in advance. :)
6 返答(返信)
337件の閲覧回数
lpcware
Content originally posted in LPCWare by vasanth on Thu Nov 03 22:09:35 MST 2011
We all satisfied... :confused:
Quote:
im afraid i'd never start with it
Hope you spend sometime with LPC...Xpresso..:)
337件の閲覧回数
lpcware
Content originally posted in LPCWare by ToBeFrank on Wed Nov 02 13:20:50 MST 2011
Quote: raghavendrabsrg
Can you provide me with the code?
No.
other wise i guess ill have to study through the whole documentation (which is not so good when compared to AVR's, but i really like the features in lpc) and hopefully write the code by myself..
This is your best plan.
337件の閲覧回数
lpcware
Content originally posted in LPCWare by raghavendrabsrg on Wed Nov 02 12:37:18 MST 2011
Quote: ToBeFrank
Makes no sense.
It seems so, its a community contest so i thought this would be a good exercise to start up with my lpc board.. and thought it would be best if i get the source code for this algorithm and Analyze it.. otherwise im afraid i'd never start with it..
I tried to write some basic code, but couldn't link the libraries/drivers.. May i ask Can you provide me with the code? it'd be great for me..
Thanks, ill try to come back and post the code if everything works good.
Have a nice day folks.. :)
337件の閲覧回数
lpcware
Content originally posted in LPCWare by ToBeFrank on Wed Nov 02 10:38:10 MST 2011
Quote: graynomad
3 Days:eek:
Sorry, but IMO there's no point even starting.
Exactly. If it truly is "[I]running pretty with an AVR 128[/I]", why would you switch chips 3 days before the deadline? Makes no sense.
337件の閲覧回数
lpcware
Content originally posted in LPCWare by graynomad on Wed Nov 02 02:11:06 MST 2011
3 Days:eek:
______
Rob
337件の閲覧回数
lpcware
Content originally posted in LPCWare by raghavendrabsrg on Tue Nov 01 06:06:47 MST 2011
Aleast quite a few snaps of code or hints would be really useful.. I'd really get started good, if i get this program running.. I'm really appreciating the LPC series for its complexity and versatility.. :)
