PCF8563
Now we just check and compare with a PCF8563 data sheet and real register value.
but our real 01h value and a data sheet value is different
our register value
01h - 0x80 , 0xC0
on data sheet
01h - N (0x00)
we compare with a TABLE 4. Formatted registers overview
can you check that problem please?
解決済! 解決策の投稿を見る。
can you catch the waveform using oscilloscope to show each bit value for your read command?
Thank you for replying
other reset register value is same all right but 01h reset register value is different with a data sheet
Table 27. Register reset value[1]
01h Control_status_2 0 0 0 0 0 0 0 0
Do you mean different lots have different default value of 0X01 register?
thank you for replying
reset value 01h real value and 01h data sheet value is different does it make any problem? or error?
PCF8563 Reset value
00h | 01h | 02h | 03h | 04h | 05h | 06h | 07h | 08h | ||
LOT | XD842 | 0x08 | 0x00 | 0x80 | 0x00 | 0x00 | 0x01 | 0x00 | 0x01 | 0x00 |
XD920 | 0x08 | 0x00 | 0x80 | 0x00 | 0x00 | 0x01 | 0x00 | 0x01 | 0x00 | |
XD915 | 0x08 | 0x80 | 0x90 | 0xF4 | 0xA2 | 0xAD | 0x94 | 0x1C | 0x85 | |
nG936 | 0x08 | 0xC0 | 0xD7 | 0xBF | 0xEC | 0xFA | 0xD3 | 0x59 | 0xB9 | |
nG038 | 0x08 | 0xC0 | 0xE8 | 0x83 | 0xF8 | 0xC7 | 0xEF | 0x76 | 0x71 |
what is about the result after your read others registers?
Only this 0X01 has read error?
other reset register value is same as data sheet ,but 01h reset register value is different with a data sheet
thank you for your replying
i will check that value and waveform , if chips make problem again i will posting again thank you
