We are using the NXP OM13086 ( lpc43s67-a70cm kit) as our evaluation board.
And we would like to add one more ethernet port with the board
to get the data from original ethernet port and transfer to the new port.
Is it possible to do so with lpc43s67 ?
If yes, any suggesstion ?
If no, any suggestion for other kit/evb-board ?
hi jeremy zhou,
Thank you for the quick reply.
If the SPI interface (J3) is already reserved for other purpose,
is there any other suggestion ?
Hi jeremy zhou,
Thanks for the explanation.
Is there any porting guide or reference for the ENC28J60 Ethernet controller development board ?
Hi Eric Chen,
Thanks for your reply.
You can find the datasheet and application note of the ENC28J60 via the below link.
ENC28J60 - Interface and Networking - Ethernet Controllers
