Hello everybody.
The typical sequence for to feed the watchdog onto one LPC1768 is the follow:
LPC_WDT->WDFEED = 0xAA; LPC_WDT->WDFEED = 0x55;
My question: is It recommended to wrap the upper two lines inside a
taskENTER_CRITICAL()
taskEXIT_CRITICAL()
section, when you enable the watchdog into a FreeRTOS environment?
I got very rare watchdog events and I start to believe that they could be caused because one task switch happens between the two rows above.
Thanks in advance.
Diego.
解決済! 解決策の投稿を見る。
Hello.
After few days of extensive tests I can confirm (on my system) that taskENTER_CRITICAL / taskEXIT_CRITICAL are not enough.
I must wrapping the watchdog trigger code with __disable_irq() /__enable_irq() macros.
Doing so It seems to woks reliable.
My system has several interrupts, mostly comes from timers and UART.
Thank you so much for the suggestions.
Best regards.
Diego.
Hi Diego Barile,
I agree with you, it'd better wrap the upper two lines inside ataskENTER_CRITICAL()
taskEXIT_CRITICAL()
TIC
Hello.
Best regards.
Diego.
