Using LPCOpen in keil with KEIL USB library
1,165 次查看
dolphinapadana
I'm using lpc1788 and KEIL 5.2.2. I want to use LPCOpen drivers in keil and also use KEIL USB library (and other libraries such as graphics library).
I have problem in the project because of LPCOpen conflicts with keil cmsis header (LPC17X_8X.h) and startup file (system_LPC177x_8x.h).
Does any body use LPCOpen in Keil with keil package libraries?
(Sorry for my bad english)
标记 (2)
883 次查看
jeremyzhou
Hi Dolphin Apadana,
The LPC177x and LPC178x CMSIS-Compliant standard peripheral firmware driver library is the choice if you want to the KEIL USB library.
LPC177x and LPC178x CMSIS-Compliant Standard Peripheral Firmware Driver Library (Keil, IAR) | www.LP...
Ping
883 次查看
dolphinapadana
Tank you for your answer.
Because i want to migrate to LPC4357 MCU and because of optimizations in LPCOpen (I like the inline functions) i decide to use LPCOpen.
I use a workaround for my project, I replace all the conflicts of CMSIS library in LPCOpen. for example i replace LPC_GPIO to CHIP_LPC_GPIO
so from this time i use CHIP_LPC_XXX keyword in my code.
The only bad thing is that i should do this work for all the other LPCOpen libraries i will use in future (Like LPC43XX).
