SSP slave select issue
841 次查看
lpcware
Content originally posted in LPCWare by Rahul mankumbare on Fri Feb 19 04:17:33 MST 2016
I am using LPC1768 SSP in SPI mode & using it in Master mode.
My slave device is Current sensor.
I am using SSP1.
When I configure P0.6 as SSEL pin in SSP1, I am able to communicate with current sensor & read current data.
When I configure P0.6 as a GPIO & make it LOW Current sensor does not respond.
I am not getting what happens when I make P0.6 as SSEL in SSP1.
I want to use 4 current sensors. So there are 3 more SSEL pins are used which are GPIO.
Now How should I communicate with all sensors using GPIO as slave select.
In my project SPI is busy in communication with other MCU's. So I have to use SSP only.
Please suggest something.
4 回复数
768 次查看
lpcware
Content originally posted in LPCWare by Rahul mankumbare on Wed Feb 24 03:56:24 MST 2016
I checked pin behaviour on DSO & followed same in program.
CS Low
data transfer  single byte
CS high
768 次查看
lpcware
Content originally posted in LPCWare by serge on Tue Feb 23 05:16:25 MST 2016
What was the answer? It may be helpfull for others on this forum
768 次查看
lpcware
Content originally posted in LPCWare by Rahul mankumbare on Tue Feb 23 04:58:21 MST 2016
Thanks for your reply.
I have got the answer before your reply.
;-)  8-)  8-)
768 次查看
lpcware
Content originally posted in LPCWare by serge on Tue Feb 23 02:55:17 MST 2016
Watch the behaviour of GPIO0_6 on an osciloscope so you will see what actualy happens.
