on the M4 core of a board with LPC4357, I would like to implement SGPIO to get data at 5MHz as SIMPLEX SLAVE SPI (unidirectional stream, MISO not involved).
Here is my configuration:
SPI_CLK -> SGPIO11, SPI_CS -> SGPIO10 (qualifier), SPI_MOSI -> SGPIO12
I cannot make SGPIO slices work to get serial data in. Watching at LPC_SGPIO regs in debug (setting breakpoints) reveals that POS is never decremented. So the swap between REG and REG_SS does not happen and my SGPIO_handler IRS is never called.
I double cheked that external signals reach the MCU setting those pins as standard GPIOs in multiplexer. They are able to fire related GPIO_handler ISRs.
Maybe I'm missing something in SGPIO configuration. I tried both single (D slice) and concatenated slices (D+O slices) without success.
In the following my source code and attached the screenshot with input signals.
I would like to know what's happening.
Thank you
void setup_SGPIO_capture(void) {
//Connect SGPIO clock to Main_PLL
Chip_Clock_SetBaseClock(CLK_BASE_PERIPH, CLKIN_MAINPLL, true, false);
LPC_SGPIO->CLR_EN_0 = 0xffff; // disable interrupting on clock
LPC_SGPIO->CLR_EN_1 = 0xffff; // disable interrupting on clock
/* Disable all counters (should be in this state after reset but just make sure) */
LPC_SGPIO->CTRL_ENABLED = 0;
/* Set all pins as input */
LPC_SGPIO->GPIO_OENREG = 0;
#define CLK_CAPTURE_MODE (1<<1) //CLOCK FALLING EDGE
#define CLKGEN_EXT (1<<2) //EXTERNAL CLOCK
#define INV_QUALIFIER (1<<8) //INVERTED QUALIFIER: CS ACTIVE WHEN LOW
#define EXT_CLK_ENABLE 1 //EXTERNAL PIN
#define CLK_SOURCE_PIN_MODE (3<<1) //SGPIO11
#define QUALIFIER_MODE (3<<5) //EXTERNAL SGPIO
#define QUALIFIER_PIN_MODE (2<<7) //SGPIO10
#define CONCAT_ENABLE (1<<11) //ENABLE
#define CONCAT_ORDER (1<<12) //2 SLICES
LPC_SGPIO->PRESET[sliceD] =
LPC_SGPIO->PRESET[sliceO] = 0;
LPC_SGPIO->COUNT[sliceD] =
LPC_SGPIO->COUNT[sliceO] = 0;
LPC_SGPIO->SLICE_MUX_CFG[sliceD] =
LPC_SGPIO->SLICE_MUX_CFG[sliceO] = CLK_CAPTURE_MODE | CLKGEN_EXT | INV_QUALIFIER;
LPC_SGPIO->SGPIO_MUX_CFG[sliceD] = EXT_CLK_ENABLE | CLK_SOURCE_PIN_MODE | QUALIFIER_MODE | QUALIFIER_PIN_MODE | CONCAT_ORDER;
LPC_SGPIO->SGPIO_MUX_CFG[sliceO] = EXT_CLK_ENABLE | CLK_SOURCE_PIN_MODE | QUALIFIER_MODE | QUALIFIER_PIN_MODE | CONCAT_ENABLE | CONCAT_ORDER;
LPC_SGPIO->POS[sliceD] =
LPC_SGPIO->POS[sliceO] = ((0x20*2-1)<<8) | (0x20*2-1); //POS & PRESET
LPC_SGPIO->SET_EN_1 = 1<<sliceD; //interrupt ONLY when slice 3/D switches data register
/* Enable counter under test to start pixel stream generation */
LPC_SGPIO->CTRL_ENABLED = (1<<sliceD) | (1<<sliceO);
int main(void)
// Disable interrupts
__asm volatile ("cpsid i");
// equivalent to CMSIS '__disable_irq()' function
setupHardware();
/* Initialize the IPC Queue */
IPCEX_Init();
NVIC_SetPriority(SGPIO_INT_IRQn,0);
// Clear all pending interrupts in the NVIC
volatile unsigned int *NVIC_ICPR = (unsigned int *) 0xE000E280;
unsigned int irqpendloop;
for (irqpendloop = 0; irqpendloop < 8; irqpendloop++) {
*(NVIC_ICPR + irqpendloop) = 0xFFFFFFFF;
//Vector table relocated to ram32
memcpy(SRAM_VECTOR_TABLE, (uint32_t*)0x0, VECTOR_TABLE_SIZE_8);
SCB->VTOR = (uint32_t)SRAM_VECTOR_TABLE; //offset
*(SRAM_VECTOR_TABLE + 47) = (uint32_t)SGPIO_IRQHandler; //47=16+31
// Reenable interrupts
__asm volatile ("cpsie i");
// equivalent to CMSIS '__enable_irq()' function
//Setup SGPIO
setup_SGPIO_capture();
//NVIC_ClearPendingIRQ(SGPIO_INT_IRQn);
NVIC_EnableIRQ(SGPIO_INT_IRQn); //Enable SGPIO Interrupt
while (1) {
MSleep(10);
return 0;
解決済! 解決策の投稿を見る。
Code is fine, maybe it was a compilation issue.
Rebuilding everything fixed it.
