SDXC LPC4357
SDXC LPC4357
lilipeeeee
      I need the sdxc library for lpc 4357  use a 64GB sd card for my project。Does this device not support SDXC mode?????
Can not open :
sdxc library for lpc 43s67
Bugreport: SD-Card on LPC18xx, LPC43xx, LPC17xx | www.LPCware.com
ZhangJennie
HI lilipeeeee
By checking,  LPC4357 does not support 64GB SDXC cards. The fix only works for 32GB SDHC.
Sorry for the inconvinience.
Have a nice day,
Jun Zhang
lilipeeeee
Thank you for your help!
ZhangJennie
Hi lilipeeeee,
This link no longer exists.
The bug fix is related an old version lpcopen. lpcopen v3.02 already fixes it.
in sdmmc_18xx_43xx.c there is this:
c_size = prv_get_bits(48, 63, (uint32_t *) g_card_info->card_info.csd) + 1;
To
c_size = prv_get_bits(48, 69, (uint32_t *) g_card_info->card_info.csd) + 1;
32G SD card works well with this fix.
Hope this helps,
Jun Zhang
lilipeeeee
lilipeeeee
I tested using this software version, but the result was that USB formatting failed and cannot be used
ZhangJennie
What's your IDE and version?
Which verion of lpcopen works under your IDE?
lilipeeeee
I tested using the program under this file  lpcopen3_02-----  "Periph-sdmmc" .  still can only recognize 32GB SDHC cards!
lilipeeeee
I use  KeilV5.34 , verion : lpcopen3_02
ZhangJennie
HI lilipeeeee
Have a nice day,
Jun Zhang
lilipeeeee
Thanks!
