SD write block on LPC540xx
546件の閲覧回数
giuseppe_sama
Good morning,
I read without problems an SD card on LPC540 trought "SD/MMC and SDIO interface".
Now I am writing a single block to SD (CMD24) and I transfer all the block (512 bytes) trought FIFO (32 bit depth and 32 bit width) without problems. But at end of transmission (latest 32 FIFO word transmitted), I receive the DCRC bit (Data CRC error) in RINTSTS register.
In effect, I transmitted 512 bytes without CRC16, but I don't know the register for save the CRC16. I need to calculate it for the block and transmit it? I need to transmit 512+2 bytes?
Thanks.
477件の閲覧回数
FelipeGarcia
Hi Giuseppe,
You do not need to calculate the CRC, the module should add it by itself. Just so I can have more information, what happens if you read the same data you have written to the SD card? Is the data corrupted?
Please let me know your findings.
Felipe
