Dear all,
I'm using lpc1768 controller external interrupts. While using interrupt pins my program getting hang to hard fault handler in program startup code. Until reset nothing will happen. I don't know how to handle this problem. Please give me a solution to solve that problem. I hope your reply .Thanks in advance.
Thanks & Regards,
Prasanth.
The default exception handler just enters a while(1) loop. To solve your problem, you need to find out what is causing the hard fault. See https://community.nxp.com/message/630605
Thanks for your reply Con Verse. I debug my code and got the cause of hard fault. But i don't have an idea to solve that. I attached a screenshot to it.
Hard fault gets occur due to instruction bus error. Please help me to solve this.
This hard fault gets occur while using an external interrupt pins else code works fine. Is have any relation between them?
Thanks & Regards,
Prasanth
Use the link I gave you to gain the knowledge to find whats going on. Hint, check LR register, find out what instruction (address) that caused the hardfault in the first place. Possibly something in your EINT3 IRQ handler ??
Dear Groen,
LR register indicating address is 0xFFFFFFF9. How to i find the instruction using this address? If i put this address to memory window it gives a message of "cannot access memory". What i want to do?
If a problem occur due to EINT3 IRQ Handler what modification i want to do to solve that?
Hi Prasanth,
I would recommend you to take a look to the periph_pinint example that comes with the LPCOpen package for the LPC1769 board, this example demonstrates use of the GPIO pin interrupts:
LPCOpen Software for LPC17XX|NXP
You can see how the GPIO interrupt is configured and enabled.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Dear Mendoza,
Thank you very much for your response. I got that example programs any verified my code with that. Now i find the cause of that hard fault handler. Actually the problem is my program logic. What i did is while occurring an external interrupt update some variables to call the function. But i didn't properly get out from the currently running function. So when i give an external interrupt continuously program gets hang with a hard fault handler.
Now i alter my code to whenever getting an interrupt get out from a currently running function and then proceed corresponding interrupt process. It works fine.
Thanks & Regards,
Prasanth.
Hi Prasanth,
Thanks for your response, It is good to hear that it is now working fine!
Carlos Mendoza
Some pointers in this article:
Application Note 209: Using Cortex-M3 and Cortex-M4 Fault Exceptions
Thanks groen. My program don't wanna go to hard fault handler. What i want to do for that?
I'm using uart interrupt,timer0 interrupt and 3 external interrupt pins in an EINT3. But i was set a priority to each block.
Am i wanna do anything more except priority set?
Thanks & Regards,
prasanth
