LpcXpresso board broken
850件の閲覧回数
dimitrissideris
It is the second board (LpcXpresso 4367) that i bought (the previous one had a problem with uart pins and suddenly didn't print out to console.)
The new one when is powered on a green led is slightly dimmed up and when i try to debug, connection to linkserver is ok but then it appers that 0 available JTAG devices detected.
Also i cannot erase chip.
The most important thing is that when the board is powered on it is heating up very quickly.
Please i need some help.
Cannot afford for a third board.
Thanks in advance.
[EDIT]
i followed instructions from here Failed on connect: Ee(XX). Could not connect to core. | www.LPCware.com
and the result of gdb trace is:
140,033 2-target-disconnect
140,034 3-gdb-exit
140,043 2^error,msg="You can't do that when your target is `None'"
140,043 (gdb)
140,043 3^exit
ラベル(2)
タグ(2)
2 返答(返信)
620件の閲覧回数
sebastienboivin
I have the same problem with one of my board, the USB port even said over power.
620件の閲覧回数
brendonslade
Hi Dimitiris,
we have contacted you directly by email about your board ... please check your email and follow up with us directly from there.
