LPCxpresso546
LPCxpresso546
1,069件の閲覧回数
blair_smyth
Hi There,
I am using the LPCXpresso546 EVM and i believe i have a build on the EVM that has hard faulted and cannot seem to conect the device to my IDE.
The probe cannot be found and i am using CMSIS DAP.
Is there a way i can erase what is on the device and reconnect?
Kind regards,
Blair
10 返答(返信)
1,048件の閲覧回数
frank_m
Senior Contributor III
This sounds like you somehow damaged it physically. The debug adapter and target are mostly independant, so the CMSIS-DAP should be found when the proper PC driver is installed.
However, they are "linked" via the power supply. If the EVM has such a possibility, check the current consumption. And/or check the supply voltages (+5V, +3.3V).
1,032件の閲覧回数
blair_smyth
Hi there,
Thanks for the reply, ive recently gotten myself a new EVM straight out of the box, i cannot seem to see the device on my computer through device manager and my IDE still cannot find the probe.
Any other ideas where i might be going wrong?
Blair
1,026件の閲覧回数
converse
Senior Contributor V
If you haven't already try different USB ports on your computer. Also try changing the USB cable. Finally, make sure you are connecting to the correct port on the large board.
1,022件の閲覧回数
frank_m
Or a different PC. It should at least show up as unknown USB device, check the device manager (under Windows).
1,016件の閲覧回数
blair_smyth
I have tried different USB ports, tried my other laptop and still isnt recognised.
I have the USB connected to j8 and perform a software reset, holding down ISP0 and toggling reset, but still no connection showing in the device manager, even as an unknown device.
I am able to use a UART programming tool and have loaded the gpio_led_output program from the SDK to the device and when loaded pressing SW2 does illuminate LED3.
So it seems the EVM is working correctly but i just cannot connect to it over USB to program or to debug with my IDE.
Blair
1,007件の閲覧回数
converse
You may need to use JP5 and LPCScrypt to reload the debug firmware image.
993件の閲覧回数
blair_smyth
Do you or anyone have the correct link for the LPCScrypt?
The one i am trying to run doesnt seem to work.
I am trying to run LPCScrypt v2.1.2 Nov 2020
986件の閲覧回数
converse
That is the latest version of LPCScrypt.
Please explain what you mean by "doesn't seem to work" - describe what happens, any messages etc.
1,060件の閲覧回数
xiangjun_rong
Hi, Blair,
You said that you use LPCXpresso546 EVM, can you tell me the concrete board name in detail? for example the LPCXpresso54608 EVM or LPCXpresso54628 EVM.
Secondly, you said that you can not connect to the board, I think this is a trick, you can hold ISP0 button, then press/release Reset button, then you can try to download the code and check if you can communicate.
Regarding the hardfault, I suppose your code has issue, pls download an example code in SDK package and have a try.
Hope it can help you
XiangJun Rong
1,054件の閲覧回数
blair_smyth
Hi Xiangjun,
I am using the LPCXpresso54628 EVM, I have tried to hold down the ISP0 button and reset, then i try to connect to the device but still no probe is found.
Even in my computers device manager there is no USB device detected.
I am able to connect to the device over UART and program bin files that way, and have uploaded an example project to the device, but i still cannot get a connection on j8 for USB.
Blair
