LPC8N04 官方Demo板无法下载程序
小林申
在使用LPC8N04  的官方的开发板的时候使用keil 编译没有出现错误,当下载程序的时候却弹出一下错误。我使用的是Keil-5.23,PACK 包使用的是1.9 , 使用的是板载的下载电路,Flash 的操作是按照例程的操作来的,请问温和会出现这种状况呢?其他人也有不少人遇到了问题,我在中国的论坛发了帖子,但是还是没有人解决。
论坛帖子链接如下:LPC 8N04无法下载程序问题以及固件无法更新的问题 - ARM Cortex-M系列产品 - 恩智浦技术社区 - 手机版 - Powered by Discuz!
Load "C:\\Users\\Administrator\\Desktop\\LPC8N04\\03-源码包\\LPC8N04-Demo\\Objects\\LPC_8N04Demo.axf"
Full Chip Erase Done.
Programming Done.
Contents mismatch at: 00000000H (Flash=80H Required=60H) !
Contents mismatch at: 00000001H (Flash=00H Required=03H) !
Contents mismatch at: 00000004H (Flash=EDH Required=49H) !
Contents mismatch at: 00000005H (Flash=7DH Required=01H) !
Contents mismatch at: 00000008H (Flash=75H Required=53H) !
Contents mismatch at: 00000009H (Flash=7FH Required=01H) !
Contents mismatch at: 0000000CH (Flash=75H Required=55H) !
Contents mismatch at: 0000000DH (Flash=7FH Required=01H) !
Contents mismatch at: 00000010H (Flash=01H Required=57H) !
Contents mismatch at: 00000011H (Flash=00H Required=01H) !
Contents mismatch at: 00000013H (Flash=20H Required=00H) !
Contents mismatch at: 00000014H (Flash=04H Required=59H) !
Contents mismatch at: 00000015H (Flash=E0H Required=01H) !
Contents mismatch at: 00000016H (Flash=0AH Required=00H) !
Contents mismatch at: 00000017H (Flash=23H Required=00H) !
Contents mismatch at: 00000018H (Flash=58H Required=5BH) !
Contents mismatch at: 00000019H (Flash=43H Required=01H) !
Contents mismatch at: 0000001AH (Flash=30H Required=00H) !
Contents mismatch at: 0000001BH (Flash=3AH Required=00H) !
Contents mismatch at: 0000001CH (Flash=80H Required=A4H) !
Contents mismatch at: 0000001DH (Flash=18H Required=F4H) !
Contents mismatch at: 0000001EH (Flash=49H Required=FFH) !
Contents mismatch at: 0000001FH (Flash=1CH Required=EFH) !
Contents mismatch at: 00000020H (Flash=0AH Required=00H) !
Contents mismatch at: 00000021H (Flash=78H Required=00H) !
Contents mismatch at: 00000023H (Flash=2AH Required=00H) !
Contents mismatch at: 00000024H (Flash=05H Required=00H) !
Contents mismatch at: 00000025H (Flash=D0H Required=00H) !
Contents mismatch at: 00000026H (Flash=13H Required=00H) !
Contents mismatch at: 00000028H (Flash=30H Required=00H) !
Contents mismatch at: 00000029H (Flash=3BH Required=00H) !
Contents mismatch at: 0000002AH (Flash=0AH Required=00H) !
Contents mismatch at: 0000002BH (Flash=2BH Required=00H) !
Contents mismatch at: 0000002CH (Flash=F3H Required=5DH) !
Contents mismatch at: 0000002DH (Flash=D3H Required=01H) !
Contents mismatch at: 0000002EH (Flash=64H Required=00H) !
Contents mismatch at: 0000002FH (Flash=48H Required=00H) !
Contents mismatch at: 00000030H (Flash=70H Required=5FH) !
Contents mismatch at: 00000031H (Flash=47H Required=01H) !
Contents mismatch at: 00000032H (Flash=80H Required=00H) !
Contents mismatch at: 00000033H (Flash=21H Required=00H) !
Contents mismatch at: 00000034H (Flash=49H Required=00H) !
Contents mismatch at: 00000035H (Flash=02H Required=00H) !
Contents mismatch at: 00000036H (Flash=88H Required=00H) !
Contents mismatch at: 00000037H (Flash=42H Required=00H) !
Contents mismatch at: 00000038H (Flash=00H Required=61H) !
Contents mismatch at: 00000039H (Flash=D3H Required=01H) !
Contents mismatch at: 0000003AH (Flash=48H Required=00H) !
Contents mismatch at: 0000003BH (Flash=1EH Required=00H) !
Contents mismatch at: 0000003CH (Flash=70H Required=63H) !
Contents mismatch at: 0000003DH (Flash=47H Required=01H) !
Contents mismatch at: 0000003EH (Flash=61H Required=00H) !
Contents mismatch at: 0000003FH (Flash=48H Required=00H) !
Contents mismatch at: 00000040H (Flash=00H Required=65H) !
Contents mismatch at: 00000041H (Flash=68H Required=01H) !
Contents mismatch at: 00000042H (Flash=C0H Required=00H) !
Contents mismatch at: 00000043H (Flash=21H Required=00H) !
Contents mismatch at: 00000044H (Flash=49H Required=65H) !
Contents mismatch at: 00000045H (Flash=03H Required=01H) !
Contents mismatch at: 00000046H (Flash=01H Required=00H) !
Contents mismatch at: 00000047H (Flash=40H Required=00H) !
Contents mismatch at: 00000048H (Flash=5FH Required=65H) !
Contents mismatch at: 00000049H (Flash=48H Required=01H) !
Contents mismatch at: 0000004BH (Flash=68H Required=00H) !
Contents mismatch at: 0000004CH (Flash=08H Required=65H) !
Contents mismatch at: 0000004DH (Flash=22H Required=01H) !
Contents mismatch at: 0000004EH (Flash=10H Required=00H) !
Contents mismatch at: 0000004FH (Flash=40H Required=00H) !
Contents mismatch at: 00000050H (Flash=08H Required=65H) !
Contents mismatch at: 00000051H (Flash=43H Required=01H) !
Contents mismatch at: 00000052H (Flash=70H Required=00H) !
Contents mismatch at: 00000053H (Flash=47H Required=00H) !
Contents mismatch at: 00000054H (Flash=5BH Required=65H) !
Contents mismatch at: 00000055H (Flash=49H Required=01H) !
Contents mismatch at: 00000056H (Flash=0AH Required=00H) !
Contents mismatch at: 00000057H (Flash=68H Required=00H) !
Contents mismatch at: 00000058H (Flash=5CH Required=65H) !
Contents mismatch at: 00000059H (Flash=4BH Required=01H) !
Contents mismatch at: 0000005AH (Flash=13H Required=00H) !
Contents mismatch at: 0000005BH (Flash=40H Required=00H) !
Contents mismatch at: 0000005CH (Flash=C0H Required=65H) !
Contents mismatch at: 0000005DH (Flash=22H Required=01H) !
Contents mismatch at: 0000005EH (Flash=52H Required=00H) !
Contents mismatch at: 0000005FH (Flash=03H Required=00H) !
Contents mismatch at: 00000060H (Flash=02H Required=65H) !
Contents mismatch at: 00000061H (Flash=40H Required=01H) !
Contents mismatch at: 00000062H (Flash=1AH Required=00H) !
Contents mismatch at: 00000063H (Flash=43H Required=00H) !
Contents mismatch at: 00000064H (Flash=0AH Required=65H) !
Contents mismatch at: 00000065H (Flash=60H Required=01H) !
Contents mismatch at: 00000066H (Flash=58H Required=00H) !
Contents mismatch at: 00000067H (Flash=49H Required=00H) !
Contents mismatch at: 00000068H (Flash=0AH Required=65H) !
Contents mismatch at: 00000069H (Flash=68H Required=01H) !
Contents mismatch at: 0000006AH (Flash=08H Required=00H) !
Contents mismatch at: 0000006BH (Flash=23H Required=00H) !
Contents mismatch at: 0000006CH (Flash=9AH Required=65H) !
Contents mismatch at: 0000006DH (Flash=43H Required=01H) !
Contents mismatch at: 0000006EH (Flash=18H Required=00H) !
Contents mismatch at: 0000006FH (Flash=40H Required=00H) !
Too many errors to display !
Error: Flash Download failed - "Cortex-M0+"
Flash Load finished at 16:07:21
Labels (3)
Tags (2)
kerryzhou
楼主你好!
不好意思,刚看你在这边发的帖子,这个问题,昨天我们已经在与非网讨论结束,并且通过更新了MDK版本解决了。
如果后面还有问题,欢迎你继续发帖交流!与非网这边都是可以的。
Kerry
