Dear Community
I have two questions regarding the LPC804 I2C subsystem
Question 1:
Table 221 (section 15.7.1) of the LPC804 user manual provides some settings for the I2C timing. To me only the row with 12 MHz seems to be useful, other clock input rates are not possible from my perspective, or did I miss something?
Especially one row assumes 30 MHz clock input and two more rows assume 24 MHz clock input to the I2C subsystem.
How can I drive the I2C subsystem with 30 MHz or 24 MHz?
The highest clock selectable via "LPC_SYSCON->I2C0CLKSEL" seems to be 15 MHz.
Question 2:
Do I need to enable open drain mode for the GPIO ports connected to I2C SDA and SCL signals?
Oliver
Hi Oliver Kraus
Yes, you are right. Table 221 is the general reference to LPC I2C module.
If you want to use I2C, you must enable IO open drain feature.
Jun Zhang
Yes, enable open drain mode please. Thus you can safely get correct data.
Jun Zhang
