LPC2368 FLASH as RAM
1,397件の閲覧回数
pazdimpazdim
Hello. I am reviewing the controller LPC2368. It has 512 kb flash ram and 32 kb ram (too few). Can I use flash memory as a ram? How slowly does it work?
タグ(1)
5 返答(返信)
980件の閲覧回数
bernhardfink
Flash can be read like a RAM from the ARM core, but cannot be written like a RAM.
If you need more RAM, then you should consider an MCU with more RAM. Or alternatively use external RAM (requires MCU with external memory bus).
Bernhard.
980件の閲覧回数
pazdimpazdim
Thanks for the answer. How to write to RAM during program execution? Any serial interface?
980件の閲覧回数
bernhardfink
SRAM or SDRAM which is connected to the memory bus is simply a memory mapped area, like the internal RAM.
So no need for any serialization.
980件の閲覧回数
pazdimpazdim
"Flash can be read like a RAM from the ARM core, but cannot be written like a RAM."
How is the writing performed in this case?
Sorry, my bad. How to write to FLASH during program execution? SPI, I2C, UART?
981件の閲覧回数
bernhardfink
Look into the specification of the respective flash device:
  • Internal flash:  data sheet & user's manual of the LPC2368 (look for "In Application Programming", IAP)
  • External flash:  data sheet of the parallel flash or serial SPI flash
