Hello everybody,
I was wondering if there is any way to interface LPCXpresso 824-max with a software like LabView, and how to actually do it.
What I need to do is quite simple: creating a user interface to change the value of an uint-type variable used by the program wrote in LPCXpresso IDE.
Thank you for your help!
Hi Valerio,
I think the easiest way of interfacing the board with Labview is using serial communication, you could route the LPC824 UART to the mbed Serial Port and use this virtual com port to communicate with your Labview serial component.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Hi Valerio,
You can use the hello world example from the LPCOpen package or the example code bundle:
Hope it helps!
Carlos Mendoza
