ISP option requirement
1,142 次查看
prachipanse
Is there a suitable document or link available where the requirement and usage of ISP programming mode is explained?
Also, for the case when this mode is not required to be used for LPC1313, how can that be achieved?
Thanks and Regards,
Prachi
4 回复数
924 次查看
ckphua
Please read the User Manual -chapter 21
http://www.nxp.com/documents/user_manual/UM10375.pdf
There you will find the details of ISP programming mode explanation.
If your application do not require the ISP,  make sure PIO0_1 pin is not tied to low during power on.
924 次查看
prachipanse
Thanks. So, for programming the flash in LPC1313 is possible only through the UART interface and is not possible if we are using only the SWD port. Can you please confirm my understanding?
Prachi
924 次查看
converse
Senior Contributor V
You can use the lpcxpresso command line flash programming tools to program your device over SWD (as well as directly in the GUI, of course)
https://community.nxp.com/thread/389139
IIRC, FlashMagic can also be used over SWD as well as UART - but you should double check.
924 次查看
ckphua
Yes, only UART ISP for LPC1313.
