I have with me LPCXpresso5411x development board. I use MCUXpresso IDE to import a project sample freertos_i2c. It can build and run the debugger. However it seems there is no I2C communication establish, the callback i2c_slave_callback() is not triggered at all.
The following init is success:
status = I2C_RTOS_Init(&master_rtos_handle, EXAMPLE_I2C_MASTER, &masterConfig, sourceClock);
However the following attempt for master to transfer data fail with status 2611:
status = I2C_RTOS_Transfer(&master_rtos_handle, &masterXfer);
if (status != kStatus_Success)
PRINTF("I2C master: error during write transaction, %d", status);
I am expecting it works just out of the box, or is there anything I miss or should preconfigure before?
已解决! 转到解答。
Hi misterbee,
There isn't any pre-configuration needed to run the i2c example. Could you please re-confirm both i2c connections?
I2C1 connected to I2C2
SCL P0_25(J1 pin1) --> P0_18(J1 pin11)
SDA P0_26(J1 pin3) --> P0_20(J1 pin13)
Can you also please confirm if you are connecting any extra boards or any other component? Did you modify the SDK example?
Best regards, Julian
Thank you @Julián_AragónM , I can see the instruction now to setup connection I2C1 <-> I2C2.
Should I expect this setup already done when I download the sdk sample? Or I have to do this in addition?
Hi @Julián_AragónM ,
It is now resolved, silly me, just realized need to do wiring to physically connect between the two I2C :D.
Thank you for showing me the instruction doc, otherwise I would not be aware of this :).
I saw this in the code, will this help to answer your question about the I2C connection?
/* clang-format off */
* TEXT BELOW IS USED AS SETTING FOR TOOLS *************************************
BOARD_InitPins:
- options: {callFromInitBoot: 'true', coreID: cm4, enableClock: 'true'}
- pin_list:
- {pin_num: '31', peripheral: FLEXCOMM0, signal: RXD_SDA_MOSI, pin_signal: PIO0_0/FC0_RXD_SDA_MOSI/FC3_CTS_SDA_SSEL0/CTIMER0_CAP0/SCT0_OUT3, mode: inactive, invert: disabled,
glitch_filter: disabled, slew_rate: standard, open_drain: disabled}
- {pin_num: '32', peripheral: FLEXCOMM0, signal: TXD_SCL_MISO, pin_signal: PIO0_1/FC0_TXD_SCL_MISO/FC3_RTS_SCL_SSEL1/CTIMER0_CAP1/SCT0_OUT1, mode: inactive, invert: disabled,
- {pin_num: '3', peripheral: FLEXCOMM4, signal: RTS_SCL_SSEL1, pin_signal: PIO0_25/FC4_RTS_SCL_SSEL1/FC6_CTS_SDA_SSEL0/CTIMER0_CAP2/CTIMER1_CAP1, invert: disabled,
glitch_filter: disabled, i2c_slew: i2c, i2c_drive: low, i2c_filter: enabled}
- {pin_num: '4', peripheral: FLEXCOMM4, signal: CTS_SDA_SSEL0, pin_signal: PIO0_26/FC4_CTS_SDA_SSEL0/CTIMER0_CAP3, invert: disabled, glitch_filter: disabled, i2c_slew: i2c,
- {pin_num: '58', peripheral: FLEXCOMM5, signal: TXD_SCL_MISO, pin_signal: PIO0_18/FC5_TXD_SCL_MISO/SCT0_OUT0/CTIMER0_MAT0, mode: inactive, invert: disabled, glitch_filter: disabled,
- {pin_num: '60', peripheral: FLEXCOMM5, signal: RXD_SDA_MOSI, pin_signal: PIO0_20/FC5_RXD_SDA_MOSI/FC0_SCK/CTIMER3_CAP0, mode: inactive, invert: disabled, glitch_filter: disabled,
* BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS ***********
/* clang-format on */
/* FUNCTION ************************************************************************************************************
* Function Name : BOARD_InitPins
* Description : Configures pin routing and optionally pin electrical features.
* END ****************************************************************************************************************/
/* Function assigned for the Cortex-M4F */
void BOARD_InitPins(void)
/* Enables the clock for the IOCON block. 0 = Disable; 1 = Enable.: 0x01u */
CLOCK_EnableClock(kCLOCK_Iocon);
const uint32_t port0_pin0_config = (/* Pin is configured as FC0_RXD_SDA_MOSI */
IOCON_PIO_FUNC1 |
/* No addition pin function */
IOCON_PIO_MODE_INACT |
/* Input function is not inverted */
IOCON_PIO_INV_DI |
/* Enables digital function */
IOCON_PIO_DIGITAL_EN |
/* Input filter disabled */
IOCON_PIO_INPFILT_OFF |
/* Standard mode, output slew rate control is enabled */
IOCON_PIO_SLEW_STANDARD |
/* Open drain is disabled */
IOCON_PIO_OPENDRAIN_DI);
/* PORT0 PIN0 (coords: 31) is configured as FC0_RXD_SDA_MOSI */
IOCON_PinMuxSet(IOCON, 0U, 0U, port0_pin0_config);
const uint32_t port0_pin1_config = (/* Pin is configured as FC0_TXD_SCL_MISO */
IOCON_PIO_FUNC1 |
IOCON_PIO_INV_DI |
/* PORT0 PIN1 (coords: 32) is configured as FC0_TXD_SCL_MISO */
IOCON_PinMuxSet(IOCON, 0U, 1U, port0_pin1_config);
const uint32_t port0_pin18_config = (/* Pin is configured as FC5_TXD_SCL_MISO */
IOCON_PIO_FUNC1 |
IOCON_PIO_INV_DI |
/* PORT0 PIN18 (coords: 58) is configured as FC5_TXD_SCL_MISO */
IOCON_PinMuxSet(IOCON, 0U, 18U, port0_pin18_config);
const uint32_t port0_pin20_config = (/* Pin is configured as FC5_RXD_SDA_MOSI */
IOCON_PIO_FUNC1 |
IOCON_PIO_INV_DI |
/* PORT0 PIN20 (coords: 60) is configured as FC5_RXD_SDA_MOSI */
IOCON_PinMuxSet(IOCON, 0U, 20U, port0_pin20_config);
const uint32_t port0_pin25_config = (/* Pin is configured as FC4_RTS_SCL_SSEL1 */
IOCON_PIO_FUNC1 |
/* I2C mode */
IOCON_PIO_I2CSLEW_I2C |
IOCON_PIO_INV_DI |
/* Low drive: 4 mA */
IOCON_PIO_I2CDRIVE_LOW |
/* I2C 50 ns glitch filter enabled */
IOCON_PIO_I2CFILTER_EN);
/* PORT0 PIN25 (coords: 3) is configured as FC4_RTS_SCL_SSEL1 */
IOCON_PinMuxSet(IOCON, 0U, 25U, port0_pin25_config);
const uint32_t port0_pin26_config = (/* Pin is configured as FC4_CTS_SDA_SSEL0 */
IOCON_PIO_FUNC1 |
/* I2C mode */
IOCON_PIO_INV_DI |
/* PORT0 PIN26 (coords: 4) is configured as FC4_CTS_SDA_SSEL0 */
IOCON_PinMuxSet(IOCON, 0U, 26U, port0_pin26_config);
Hi misterbee,
Thank you for the response. I don't connect to any board nor I modify the SDK. I just take a fresh board and load the sample from the IDE.
Where can check this? From the code? which file/function?
"I2C1 connected to I2C2
SDA P0_26(J1 pin3) --> P0_20(J1 pin13)"
Hi @misterbee,
This is in the "readme" file under docs folder in your project folder. It can be found in "...\Documents\MCUXpressoIDE_11.5.1_7266\workspace\lpcxpresso54114_freertos_i2c\doc"
There you can find the instructions to run the project.
