How to write my first program
921件の閲覧回数
lpcware
Content originally posted in LPCWare by kamhagh on Wed Sep 10 06:29:17 MST 2014
LPC1768 Cortex-M3 Header board
this is my board!
i installed LPCXpresso on linux but i have no idea what to do,
and where to start learning, i already knwo how to programm for avr, i don't know what to select during creating a new project, i searched google a lot and didn't find anything useful :(
13 返答(返信)
862件の閲覧回数
lpcware
Content originally posted in LPCWare by kamhagh on Thu Sep 11 00:57:44 MST 2014
thanks a lot,
i will order one today, i remember when i started avr i was just like this :D
862件の閲覧回数
lpcware
Content originally posted in LPCWare by LabRat on Wed Sep 10 12:21:40 MST 2014
Quote: kamhagh
edit: oh, by how to make (one) i ment an working applications, i am mostly  looking for an start point to make my "hello work" (assuming an led blink :) ) or something and keep going further !
This simple LED blinking project is your start point  :O
System init and Startup file in your source folder are showing you what's necessary to use LPC17xx chips.
Modern chips and toolchains are complex  :)
BTW: Using Atmel's ASF with something like ATSAMR21 isn't easy either...
If you are trying to understand LPC17xx it's a good idea to try this samples and read UM10360. Then you'll learn how this chip is working and if it's a good choice for you...
862件の閲覧回数
lpcware
Content originally posted in LPCWare by kamhagh on Wed Sep 10 11:40:57 MST 2014
i understood how to make the new project
i imported all of the projects from there
i opened periph_blinky and then i went to emaple/src/ there are 3 files(.c) i have no idea what each are, anyway i opened 3 of them , one of them was just bunch of # if and #ifdef and ect
other one was same
but systick.c was simple. and just called some functions, i have guessed what those do, but still don't understand them correctly
and i have never even seen the Chip / board libaries ! i only programmed for arduino and AVR , thats my only experiance in electronics, other than that i programmed computer ,
i have already used Eclipse before for Android and java programming !
862件の閲覧回数
lpcware
Content originally posted in LPCWare by kamhagh on Wed Sep 10 11:25:30 MST 2014
it showed how to import projects not how to make one,
i opened blinky example and i didn't understand anything there !
i found a datasheet or something that tells me what register is what, but not how to change them !
i live in iran, youtube is banned
862件の閲覧回数
lpcware
Content originally posted in LPCWare by LabRat on Wed Sep 10 11:11:21 MST 2014
http://www.lpcware.com/system/files/LPCXpresso_User_Guide_0.pdf
is also describing how to create new projects....
Anyway, as a beginner you should try to import a blinky example (LPCOpen)...
That's helping you to understand how basic mechanisms are working (Eclipse/ IDE / SWD / Debugging)...
If you are more familiar with Chip / Board libraries you'll find User Manual (http://www.nxp.com/documents/user_manual/UM10360.pdf) Registers in Library functions.
At the moment creating new projects is more confusing you than helping to understand basics  :)
862件の閲覧回数
lpcware
Content originally posted in LPCWare by kamhagh on Wed Sep 10 09:59:05 MST 2014
i couldn't edit the prev post ! but i only saw stuff about how to use IDE,
862件の閲覧回数
lpcware
Content originally posted in LPCWare by LabRat on Wed Sep 10 09:57:21 MST 2014
Quote: kamhagh
btw i can't open Youtube :( its forbidden :(
BTW: You can update your accout location to give us a hint if you're living in a 'forbitten' country...
Quote: kamhagh
no, i mean how i can start learning how to program LCP1678 like how to turn the pin on and off how can i do : digitalWrite(1,HIGH);(arduino) in the LPC1678,
that says how i can make projects and ect!
And it should show you how to import projects. I'm not sure if LPCXpresso comes with LPC1678 samples, but a lot of LPC1768 samples are available with LPCOpen:
http://www.lpcware.com/content/nxpfile/lpcopen-software-development-platform-lpc17xx-packages
Is that forbitten, too?
862件の閲覧回数
lpcware
Content originally posted in LPCWare by kamhagh on Wed Sep 10 09:48:26 MST 2014
the http://www.lpcware.com/lpcxpresso had an 2 page pdf !
im sorry if i'm annoying you :(
let me relog to linxu and relook at the user manual!
EDIT: can't find the installation directory, its not on home, let me keep searching :|
862件の閲覧回数
lpcware
Content originally posted in LPCWare by LabRat on Wed Sep 10 09:09:49 MST 2014
Quote: kamhagh
but i searched net a lot and i can't find a single thing on how to learn it :(
:quest:
Then something's wrong with your Google...
https://www.youtube.com/watch?v=dV7rG2VdG9E
https://www.youtube.com/watch?v=cLvGwmJAA7k
And last not least:
https://www.youtube.com/watch?v=E6vSPloei-0
862件の閲覧回数
lpcware
Content originally posted in LPCWare by TheFallGuy on Wed Sep 10 09:01:03 MST 2014
As I said earlier, start with the user manual. It is in the install directory. It is also available on the download page.
862件の閲覧回数
lpcware
Content originally posted in LPCWare by kamhagh on Wed Sep 10 08:29:12 MST 2014
oh god im so confused and my brain is so dirty  :D i can't understand anything
let me ask this question
i just want to start learning LPC1768, what should i do to learn it?
like when i wanted to learn arduino and avr, i just googled arduino tutorial, it had some info and i learned it :D
862件の閲覧回数
lpcware
Content originally posted in LPCWare by kamhagh on Wed Sep 10 07:18:33 MST 2014
thanks for quick reply,
i have lots of documents and stuff in my downloads folder , im confused which one your talking about, can you give me a link or something?
i read it again. i used none and it fixed error, but anyway were can i start learning how to prorgam those ?!
862件の閲覧回数
lpcware
Content originally posted in LPCWare by TheFallGuy on Wed Sep 10 06:31:19 MST 2014
Read the user manual. There is a getting started tutorial provided.
