Define a class
Define a class
1,041 次查看
thoret
I try to write a simply programm and I want to define a class linke:
class myclass{
Directly I get an syntax error.
After I bulid the project I get an error:
Multiple markers at this line
    - Syntax error
    - unknown type name 'myclass'
    - expected '=', ',', ';', 'asm' or '__attribute__' before
     '{' token
I try to write it in a .h file and a .c
I work with LPCxpresso 8.2.2_650
I try to implemented math.h but the error still exist.
I think he dosn't know "class" but why? It is C syntax, isn't it?
标签 (2)
895 次查看
thoret
Thank you Guys.
It works.
895 次查看
kerryzhou
Hi Thore T,
    Fall Guy is correct, Class is the data type for C++, not for C, so if you want to use the class type, please create a C++ source file instead of C file.
Wish it helps you!
If you still have question, please contact me!
Kerry
895 次查看
thefallguy
Class is C++ and not C. In lpcxpresso you need to creat a C++ project and .cpp file for your code.
