Debug Customer's System with Link2 Not Providing Enough Power
1,214件の閲覧回数
leechen
I have this question that if my customer's system require large power to operate, which is much bigger than the electric current Link2 can provide. How should I debug my customer's system with Link2?
タグ(1)
11 返答(返信)
965件の閲覧回数
jeremyzhou
Hi  Lee Chen,
Thank you for your interest in NXP Semiconductor products and
the opportunity to serve you.
The custom board is able to be supplied by an alternative power source when JP2 is open in the LPC-link2.
TIC
965件の閲覧回数
leechen
Thank for reply Jeremy.  Do you mean when customer's board has power supply itself, I need to leave JP2 open, with Link2 connected to customer's board with only SWCLK, SWDIO, and GND?
965件の閲覧回数
jeremyzhou
Hi Lee Chen
Yes, it's.
TIC
965件の閲覧回数
leechen
but I get this error when I have JP2 open. Picture as shown below.
965件の閲覧回数
jeremyzhou
Hi Lee Chen,
Thanks for your reply.
You should remove jumper of JP1 if you want to debug the target board with LPC-link2.
TIC
965件の閲覧回数
leechen
Yes I did have both JP1 and JP2 removed as shown on the picture above.
965件の閲覧回数
jeremyzhou
Hi Lee Chen,
Sorry, I made a typo error.
It should be "You shouldn't remove jumper of JP1 if you want to debug the target board with LPC-link2."
TIC
965件の閲覧回数
lpcxpresso_supp
If the customer is using a different supply, there's no reason for the LPC-Link2 to supply power. So, leave it unconnected.
Thanks and regards,
MCUXpresso Support
965件の閲覧回数
leechen
I am having a problem that when it's 2.9V on customer's board, I can use Link2 to go into debug mode. However, after customer raised the voltage to 3.4V, I cannot go into debug mode. I don't understand why this is happening. Is there any way I can use oscilloscope to see what's causing the problem?
965件の閲覧回数
leechen
965件の閲覧回数
leechen
