Hello.
I am trying to load my code into a LPC2129 with ULINK2 and appears an error message saying: "Could not stop ARM device! Please check the JTAG cable". I tried to change the JTAG clock to 100 kHz and did not work. I tried with another ULINK2 but nothing changes.
If anybody could help me I would be so glad.
Alessandro
已解决! 转到解答。
According to the errata sheet for the LPC2129 and LPC2129/01:
"Pin TD1 (pin 10) must not be driven LOW during reset. If LOW on reset the device behavior is undetermined."
Make sure this pin is low during reset.
You can also try holding pin P0.14 low during Reset. This will cause the device to enter bootloader mode. While in bootloader mode, you should be able to regain control of the LPC2129/01 using the JTAG interface.
Sol
Please check the following link and let me know if this helps,
http://www.onarm.com/forum/8145/
Sol
Sol
Hello Soledad.
First, I tested P0.10 to LOW but did not work, then I tested P0.14 to LOW and it worked. When I tried to debug I have to quit P0.14 from LOW but does not matter, now I can load the code and use the board.
Thank you for your help.
Alessandro
