KDS KSDK MQX application size
1,526件の閲覧回数
sudhakarp
Contributor V
am using FRDMk64f120 kinetis processor, once i builed MQX example project(hello) the debug code size was exceeding more than 1mb.i checked both CW10.6 and also KDS v2.0.0. i think i want to remove library files but i dnt know how to remove. please give some solution. and also tell how to use example project.
7 返答(返信)
866件の閲覧回数
DavidS
Hi Sudhakar,
I started this as a new thread.
Are you looking at the *.elf file size?  Or are you opening and reviewing the *.map file?
The *.elf size can be very large but that doesn't correlate to the actual flash image size.  The GCC tools are very verbose with debugger information that makes the *.elf file size very large as compared to proprietary compilers (IAR/Keil/etc).
David
866件の閲覧回数
sudhakarp
Contributor V
am looking *.elf file. if file size more than 1mb means i cant dump that project through openSDA (mbed). how to debug that project throught KDS IDE
866件の閲覧回数
ivadorazinova
Hello sudhakar p,
in KDS : please, right click on the project > Properties > C/C++ Build > Settings and set Create flash image and Print size.
After that, srec file is created (in Debug folder) - the file you can copy though the OpenSDA.
I hope it helps.
Iva
866件の閲覧回数
sudhakarp
Contributor V
thank you.. now i got 152kb *.hex file, but i can't dump code using mbed(openSDAv2). what can i do for that how to dump that code into controller using OPENSDAV2. actually i need *.bin file to dump code into controller using mbed OPENSDAV2 .i tried this one also project >> c/c++ >>setting >>build artifact there i changed artifact extension into .bin but code size was exceeding more than 1mb. please give some solution
866件の閲覧回数
ivadorazinova
Hi sudhakar p,
I think there is another problem. Please, check J-Link firmware for your board. Here is good tutorial Segger J-Link Firmware for OpenSDAv2 | MCU on Eclipse
Iva
866件の閲覧回数
sudhakarp
Contributor V
hi iva Dorazinova,
          thank u very much, finally i succeed "hello world" project. its printing hello world character. i followed your instruction finally i got solution thank u everyone..
866件の閲覧回数
ivadorazinova
Dear sudhakar p,
you are welcome!
Iva
