Is there a sample somewhere, that shows how to utilize HS USB on the Kinetis devices that support it - specifically, K65/K26?
839件の閲覧回数
alexfeinman
I have a K26 project where the device is used as a USB bridge to connect a set of remote peripherals to the host. Previously it has been using K22, but now that I need to service even more components, I'd like no longer be restricter by USB FS. So two questions I had in mind:
1) Am I right that K26 does not require an external PHY for HS mode and
2) IS there a sample that expose HS USB controller at least to the SDK level (no class implementations, just a vendor device)?
680件の閲覧回数
Paul_Tian
Hi, Alex
1. Yes, there is no need an external PHY in your circuit.
2. Sorry, there is no example now. But you can wait KSDK version 1.3.
Best Regards
Paul
2 返答(返信)
681件の閲覧回数
Paul_Tian
Hi, Alex
Best Regards
Paul
680件の閲覧回数
alexfeinman
Thank you. Don't suppose you have an ETA for SDK 1.3?
