I'm trying to use the sdk driver examples about flexio uart(use FRDM-K82F board). I found that everything is ok when I use baud higher than 38400. When I use the baud lower than 38400, the data is error.
Any suggestions for how to find/fix the problem?
Example Code as below:
lpuart_state_t lpuartStatePtr;
flexio_user_config_t userConfig =
.useInt = true,
.onDozeEnable = false,
.onDebugEnable = true,
.fastAccessEnable = false
// Enable clock for PORTs, setup board clock source, config pin
hardware_init();
// Call OSA_Init to setup LP Timer for timeout
OSA_Init();
FLEXIO_DRV_Init(s_flexioInstance,&userConfig);
FLEXIO_DRV_Start(s_flexioInstance);
/* Fill in FlexIO UART config data */
flexio_uart_userconfig_t uartConfig;
uartConfig.bitCounter = kFlexIOUart8BitsPerChar;
uartConfig.baudRate = 9600;
uartConfig.uartMode = flexioUART_TxRx;
uartConfig.txConfig.pinIdx = 0;
uartConfig.txConfig.shifterIdx = 0;
uartConfig.txConfig.timerIdx = 0;
uartConfig.rxConfig.pinIdx = 2;
uartConfig.rxConfig.shifterIdx = 1;
uartConfig.rxConfig.timerIdx = 1;
/* init the FlexIO simulated UART module with base address and config structure*/
FLEXIO_UART_DRV_Init(s_flexioInstance, &uartState, &uartConfig);
while(true)
FLEXIO_UART_DRV_SendData(&uartState, txBuff, DATA_LENGTH);
flexio_uart_reset_buffer(rxBuff,DATA_LENGTH);
FLEXIO_UART_DRV_ReceiveDataBlocking(&uartState, rxBuff, DATA_LENGTH,5000U);
Solved! Go to Solution.
I found that it will configure register FLEXIOx_TIMCMPn(FLEXIO_UART_DRV_Init->FLEXIO_UART_Tx_HAL_Configure).
When flexio uart's baud is 9600, CMP[7:0] is not enough to store the value.
How could I resolve this problem?
