Convert non-KSDK project to KSDK
585件の閲覧回数
kevinpenn92
I've been developing a project for a while using the non-KSDK version of the MK21FN1M0VLL12 processor in processor expert to setup hardware.  I'm working on implementing support for a micro SD card and would like to use the KSDK version now as there is better support for the micro SD.  Is it possible to convert a project setup initially without the KSDK to a project that uses the KSDK?
429件の閲覧回数
Jorge_Gonzalez
Hello Kevin Penn:
Unfortunately there is not a direct migration path from the legacy Processor Expert to a project using KSDK drivers.
The best and cleanest approach is to start with a base project and replicate the application using the new drivers.
- With the Kinetis SDK Project Generator you can create a new project or clone one of the existing KSDK example projects:
New Kinetis SDK Project Generator v2 is available!
- If using KDS then you can use the Kinetis SDK v2.x Project Wizard:
Using Kinetis Design Studio v3.x with Kinetis SDK v2.0
Jorge Gonzalez
