I generated the code from the KMS GUI and I was testing the current control. The motor speeds up pretty smooth using the interface. However, when I tried from the code generated, the motor tries to start apparently with much higher torque then a fault comes up and the motor stops abruptly.
Here follows the code snippet I inserted in order to use current control:
if(GPIO_DRV_ReadPinInput(kGpioSW3) == 0){
switch(user.state){
case USER_BRAKE:
user.state = USER_IDLE;
break;
case USER_IDLE:
case USER_RUN_CURRENT:
user.command.statorRefCurrent.q = _SQ(0.3/FULL_SCALE_CURRENT);
user.state = USER_RUN_CURRENT;
break;
default:
break;
else{
brake.config.brakingType = BRAKE_COAST;
user.state = USER_BRAKE;
//Update drive module
DRV_updateSlowTick();
Could you please help me solve this problem?
Thanks Pedro, you are great!
if(GPIO_DRV_ReadPinInput(kGpioSW2) == 0){
switch(user.state){
case USER_BRAKE:
break;
case USER_IDLE:
break;
user.command.statorRefCurrent.q = _SQ(0.5/FULL_SCALE_CURRENT);
break;
default:
break;
else{
It seems to me that at the first time you move from IDLE to CURRENT, the control sets an initial speed value to follow, so you need to set a current when you are already in the CURRENT mode
I tried to use _SQ15(), but it did not work either.
What am I missing??
