Randy,
It is possible to operate on fractional RPM in KMS. The GUI uses whole RPM since most people don't need the motor to spin that slowly. I will also caution you that this will only work reliably if you are running Sensored Velocity or Sensored Position control. Running below about 10% of rated speed is difficult when using Sensorless Velocity.
I've written up some instructions to get fractional rpm working through the GUI below.
The speed value in the GUI will be 0 since they are not configured to display fractional numbers.
Randy,
Adam,
Thank you, that did allow me to operate below 1 RPM.
Is there a way I can get the low RPM when I am using the Motion Planner? I
am trying to set the plan velocity using the STPOSPLAN_addCfgTran()
function; regardless of the velocity I give it 1 RPM is as low as I can go.
Thank you,
Randy Fields
On Tue, Apr 3, 2018 at 11:41 AM, linestream-adamreynolds <
Randy,
You will need to manually modify the speeds in the generated MotionSequence.c file. The VEL_PU normalizing macro accepts floating point inputs. You can create your motion sequence in Motion Sequence Builder and than change the speeds manually in the MotionSequence.c file.
