Does the 33HB2001 chip CCP pin come equipped with reverse current protection?
mingentay
I have several 33HB2001 chips to power several loads. Their CCP pins, while each having their own charge pump, are also connected in parallel with each other. I'm concerned that if any of these CCP pins had a lower voltage than any of the other, current may flow into those pins and potentially damage my chips.
Tags (2)
