vector table location
699 次查看
AsafTv
I use MK64FN1M0xxx12
I configure The start Address of the program in the MCU Settings PROGRAM_FLASH to 0x26000
but the vector interrupt is placed in 0x28000 i see it in the map file
how can i move the vector to 0x26000?
What I'm doing wrong?
0x00026000                __base_PROGRAM_FLASH = 0x26000
                0x00026000                __base_Flash = 0x26000
                0x00100000                __top_PROGRAM_FLASH = 0x100000
                0x00100000                __top_Flash = 0x100000
                0x20000000                __base_SRAM_UPPER = 0x20000000
                0x20000000                __base_RAM = 0x20000000
                0x20030000                __top_SRAM_UPPER = 0x20030000
                0x20030000                __top_RAM = 0x20030000
                0x1fff0000                __base_SRAM_LOWER = 0x1fff0000
                0x1fff0000                __base_RAM2 = 0x1fff0000
                0x20000000                __top_SRAM_LOWER = 0x20000000
                0x20000000                __top_RAM2 = 0x20000000
                0x14000000                __base_FLEX_RAM = 0x14000000
                0x14000000                __base_RAM3 = 0x14000000
                0x14001000                __top_FLEX_RAM = 0x14001000
                0x14001000                __top_RAM3 = 0x14001000
.text           0x00028000    0x232d8
FILL mask 0xff
                0x00028000                __vectors_start__ = ABSOLUTE (.)
*(SORT_BY_ALIGNMENT(.isr_vector))
.isr_vector    0x00028000      0x198 ./startup/startup_mk64f12.o
                0x00028000                g_pfnVectors
                0x00028000                __Vectors
                0x00028198                . = ALIGN (0x4)
                0x00028198                __section_table_start = .
685 次查看
jingpan
Hi @AsafTv ,
Please download TWR-K64F sdk. There is a bootloader application demo in SDK_2_7_0_TWR-K64F120M .zip\boards\twrk64f120m\bootloader_examples\demo_apps.
It put application in 0xa000. The key is the link file(*.ld). You can refer to it.
Jing
