Always I am indebted.
Master-slave communication is being confirmed using “SDK_2.6.0_MKE04Z128xxx4 \ boards \ frdmke06z \ driver_examples \ i2c \ interrupt_b2b_transfer \ slave".
Added kI2C_SlaveTransmitAckEvent to i2c_slave_callback () routine, but does not break there.
When does this event occur?
Is there an API to set ACK / NAK to output manually?
Thank you.
jun.
解決済! 解決策の投稿を見る。
Hello Jun,
Are you using another board to work as master? If so, could you please specify what kind of data you are sending using this peripheral. So that I can try to reproduce this from my end.
Sabina
Hello Jun,
Sabina
Thank you very much.
I'll try.
jun
