Freescale changed the format of the Kinetis part number when the part went to production. The PK series are pre-production parts. The MK60DN512ZVLQ10 is the functional equivalent to your part.
I use latest version of CW V10.2 + update and I have not encountered a problem with selection of such package. Could you please specify what version do you use?
Donwload page:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MCU10&fpsp=1&tab=Design_Tools_Tab
best regards
Vojtech Filip
Processor Expert Support Team
Thanks for your answer.
I'm using:
- CodeWarrior for MCU
Version: 10.2
Build Id:120126
And when I want to choose the device package (Project -> Change device/Connection), the only packages that I can select are (in Kinetis K60):
MK60DN512ZVLQ10 144 pins LQFP
MK60DN512ZVMD10 144 pins MAPBGA
MK60DN512ZVMC10 121 pins MAPBGA
MK60DN512ZVLL10 100 pins LQFP
And my device package is PK60N512 VLQ100. So, where I can found it? Or I can use another to replace it?
Thanks.
