Using EEPROM of MKE02Z64VLH2
1,325件の閲覧回数
faisalaslam
Hello ,
I am using "MKE02Z64VLH2" and want to know how can i read & write to 256B EEPROM. I am using codewarrior. Is there any library or i can use the flash module from processor expert as well##?
Thanks in advance.
タグ(2)
1,181件の閲覧回数
mjbcswitzerland
Specialist V
See http://www.utasker.com/kinetis/KE_EEPROM.html
and the links below for KE02 EEPROM discussion, code and simulation of its operation.
Mark
Kinetis: http://www.utasker.com/kinetis.html
Kinetis KE:
- http://www.utasker.com/kinetis/FRDM-KE02Z.html
- http://www.utasker.com/kinetis/FRDM-KE02Z40M.html
- http://www.utasker.com/kinetis/FRDM-KE04Z.html
- http://www.utasker.com/kinetis/FRDM-KE06Z.html
- http://www.utasker.com/kinetis/FRDM-KE15Z.html
EEPROM http://www.utasker.com/kinetis/KE_EEPROM.html
Free Open Source solution: https://github.com/uTasker/uTasker-Kinetis
Working project in 15 minutes video: https://youtu.be/K8ScSgpgQ6M
For better, faster, cheaper product developments consider the uTasker developer's version, professional Kinetis support, one-on-one training and complete fast-track project solutions to set you apart from the herd : http://www.utasker.com/support.html
