Hi everyone,
I have problems to establish communication between K10 and jtag probe. I use 2 differents probe : an Olimex ARM-USB-OCD-H and a Segger JLink. Both are used with OpenOCD on Linux and windows. And with both, I obtain that same error message :
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: k10.cpu: IR capture error; saw 0x00 not 0x01
Is someone have an idea to manage this issue ?
Thanks in advance
解決済! 解決策の投稿を見る。
Thank you for your answer. We found yesterday the problem : we forgot pull-up on NMI pin (PTA4, pin54 for K10FN1M0xxx12)...
Thank you also for your kind proposition of help
Could you provide the K10 JTAG related circuit?
If yes, we could check the K10 JTAG related schematics.
Customer also could check TWR-K20D50M board schematics about JTAG related circuit design.
Wish it helps.
Ma Hui
