Hello. We believe , found the cause of failure. Output STB is not pulled to the ground ! The resistor R66 (4.7 ohm ) , which is the diagram in pdf on the card has not been set in TRK-KEA! Soldered resistor and it worked . I can not understand why he was not there ?!
Среда, 3 июня 2015, 13:18 -07:00 от david_diaz <admin@community.freescale.com>:
>The problem with the passage of data packets over CAN bus
>reply from David Diaz Marin in Kinetis Microcontrollers - View the full discussion
