Potentiometer problem of TWR-K53N512: wrong reading
649 次查看
jerrylian
I just bought the kit TWR-K53N512 a few days ago:
* I just run the demo code from accompanying DVD
* On the first day or two, potentiometer reading can range from 0-100% when I rotate it
* Later on, the reading can only range from 0-2%
Could be a defect of the board? Anyone has similar problems?
标记 (1)
509 次查看
miduo
Please make sure that the Jumper JP1 is ON if would like to read the ADC1_DM1 pin of the Potentiometer.
509 次查看
jerrylian
Yes, JP1 is already ON, otherwise I couldn't read from potentiometer. The problems:
* At the beginning, the reading ranges from 0-100.
* Now, the reading ranges from 0-2 only.
* By the way, the reading of build-in temperature sensor is always zero now.
* (It seems to be correct at the beginning days!)
