Exist some library to control the SSD1306 via I2C with the FRDM-K64F?
i have recently post it. This is my solution with i2c.
Hi Javier,
Do you still have any question about this topic?
Kerry
Thank you, I have left this for a few weeks.
Hi Javier,
If you still have question about this case, please update it.
If your question is solved, please help to mark the correct answer, just to close this case, thank you!
Kerry
There is a Processor Expert component (McuOnEclipse Components: 26-Dec-2017 Release | MCU on Eclipse ) which supports both SSD1306 and SH1106.
If not using Processor Expert, the plain C files are here: McuOnEclipseLibrary/McuSSD1306.c at master · ErichStyger/McuOnEclipseLibrary · GitHub
A project for FRDM-K64F is available here: mcuoneclipse/Examples/KDS/FRDM-K64F120M/FRDM-K64F_SSD1306 at master · ErichStyger/mcuoneclipse · Git...
I hope this helps,
Erich
Thank you, I have seen the project in github but it's for PE.
