Need a Firmware flashing tool for mkl26z128vft4 . Kindly advice.
1,434 次查看
adityanagal1
Hi ,
We are using mkl26z128vft4 in a product . We are looking for a firmware flashing tool for the same .
Kindly advice.
Aditya Nagal
4 回复数
1,388 次查看
ramprakash08
For flashing firmware on the mkl26z128vft4, you can use the MCUXpresso IDE. This IDE supports various debugger hardware including Segger, LPCLink, and J-Link. Once you have connected your device to your PC, you can simply start a debug session and the IDE will automatically detect your debug probe.
1,415 次查看
Pavel_Hernandez
Hello, the IDE has support for different debugger hardware, which will be from Segger, LPCLink, J-Link. Only connect your device to your PC an click the button to start debug session this will try to find your debug probe.
Pavel
1,391 次查看
adityanagal1
HI Pavel,
Thank you . Bur we are not looking for the debugger device . We simply need a programmer for flashing the device .
Thanks & Regards,
Aditya
1,381 次查看
ErichStyger
Specialist I
You can use a command line utility, e.g. the LinkServer, see https://mcuoneclipse.com/2023/05/14/linkserver-for-microcontrollers/
Or see https://mcuoneclipse.com/2020/12/05/standalone-and-command-line-programmer-with-mcuxpresso/ for other options.
It all depends on the hardware probe you are having and using.
