MK60DN512VMD10 MCU question
超贡
MCU is MK60DN512VMD10 and I use a example(hello_world) in SDK_2.2_MK60DN512xxx10(download from NXP).
When I  debug it, I found it's MCG->S register is alway 0x10 and the program is run at "while ((MCG->S & (MCG_S_IREFST_MASK | MCG_S_CLKST_MASK)) !=(MCG_S_IREFST(kMCG_FllSrcExternal) | MCG_S_CLKST(kMCG_ClkOutStatExt)))". It means the MCG->S didn't change. I tried both Keil and Kinetis Design Studio 3 IDE, but the question is the same.
My schematic is connect a 50MHz to PTA18(M12). PTA19(M11)、EXTAL32(M6) and XTAL32(M7) is NC。
kerryzhou
Hello customer,
   SDK_2.2_MK60DN512xxx10 is for our TWR-K60D100M board.
  It seems you are using your own board.
  Your problem that the code is stopping tin the MCG_S register, normally it is caused by your external clock.
  You said you are connecting the 50Mhz to PTA18, please check the PTA18 pin with oscilloscope, whether this pin really have 50Mhz, this is very important.
Wish it helps you!
If you still have question about it, please let me know!
Kerry
kerryzhou
Hello customer,
Wish it helps you!
Kerry
