Kinetis Protocol Analyzer & USB-KW019032 adapter not found
1,085件の閲覧回数
ikivela
I just bought USB-KW019032 and tried to follow the steps in "Getting started guide"
I installed the drivers and see mbed Serial Port when dongle is connected
However, when I launch Kinetis Procotol Analyzer, I don't see adapter detected.
I am using Windows 10. Protocol Analyzer version is 2.0.4.1
What am I doing wrong?
6 返答(返信)
1,045件の閲覧回数
ikivela
The problem persist. I can't run KPAA (version 2.0.2.1) it complains that I don't have Wireshark installed (3.2.0) eventhough I have it
1,037件の閲覧回数
nxf56274
1 Did you close the firewall?
2 Did you put the software in 'c:/nxp'?
1,030件の閲覧回数
ikivela
Yes, I did that.
I also tried Test Tool 12.6.3 but it did not either detect the device.
989件の閲覧回数
nxf56274
The Kinetis Protocol Analyzer doesn't support USB-KW019032. kw01 works on 1Ghz. The Kinetis Protocol Analyzer works on 2.4Ghz. So the only way is to use the test tool including the protocol analyzer.
So you have followed the guide and use test tool to open the protocol analyzer?
1,072件の閲覧回数
ikivela
I download older version of KPAA  2.0.2.1 and Wireshark 3.2.16, but now I can't start KPAA because of error:
"Wireshark is not detected on your PC"
1,080件の閲覧回数
nxf56274
Please refer this link.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
