I developed a project with Kinetis PK70 to 120MHz.
I'm going through the production with the Kinetis MK70 up to 150MHz.
Wondering if the firmware developed with CodeWarrior 10.3 and MQX 3.8, are compatible or need to change the setting to run MK70.
thanks
Maurizio
解決済! 解決策の投稿を見る。
Hi Maurizio, most likely you would have to change a couple of register settings in the MCG module, aside from that your code does not need to have any changes.
hello.
is there a new BSP for the MK70 ?
have the same problem .. we are using the MQX ..
