Kinetis K-10 Interrupt latency question.
1,045件の閲覧回数
anatolyodler
Hello, all.
We're working with Kinetis K-10 MCU. No operating system.
What is the interrupt latency of the context switch between an background thread (main function) and PIT interrupt?
What happens, if other interrupt, with higher priority that the PIT, enters in the middle of that context switch?
Thank you.
2 返答(返信)
748件の閲覧回数
deepakrana
hi
For the cortex M interrupt handling the ARM info centre gives the best information and is part of their documentation. The interrupt handling for all Cortex M series is under ARM control.
More info on the interrupts check this link:
ARM Information Center
There are two important concepts in interrupt handling of cortex M - tail chaining and later arrival concept
This you can check at link
You need to right click on these links to open the right link under the name shown.
The above should help with all the questions that you have asked.
748件の閲覧回数
deepakrana
hi
hope this helped in you understanding of your problem
