There is a reference design (DRM143) based on KM3x for a single phase metering application using filter-based algorithm (as covered in AN4265).
DRM143
AN4265
The source code is built with libraries (fraclib.a, meterlib.a).
Where can I get the source code for those libraries?
Thanks.
Devan
Hi Devan,
The fraclib.a and meterlib library source code need to sign a NDA agreement.
After you sign the NDA agreement, you could contact with your local Freescale Distributor to get the source code.
The distributor network could be found from here.
Ma Hui
Hi Ma Hui,
Thanks for the response.
In fact, I'm an FAE working for a distributor and this is for one of our customers. I will organize an NDA with the customer.
Devan
