Hi d4712,
KL26's PORT B does not support interrupt, so it does not have an interrupt vector either.
Robin
Yes it does, you can find it (and the other vectors) in the startup_,,, file (I'm not sure what the full name is for the KL26Z) in the "startup" folder (it should be the only file in the folder.
As a default, all the interrupt vectors are given the address of a simple handler that clears the interrupt request flags and return. This handler is defined as a "weak" method that you can easily replace simply by defining a new handler.
Take a look at one of the example apps in the SDK to see how you can create your own handler.
