KL16 Security Issue
KL16 Security Issue
1,100 次查看
ScottKerstein
User code on KL16 runs fine; however, when security fsec is enabled, the micro reset every 1msec.  What could the problem be?
Thanks, in advance,
Scott
884 次查看
tommyp
Hi All, I found the problem.  During development, the CodeWarrior flashes via ELF file.  When I attempted flashing Hex from P&E Max, the hex file failed.  I did not output all required sections, resulting in a bad image and the behavior I experienced.
Thanks!
5 回复数
885 次查看
tommyp
Thanks!
884 次查看
tommyp
A little more info.  When secured, the reset line only goes to 2volts.  Unsecured it goes to 3.3v.
884 次查看
Hui_Ma
Hi Tom,
Could you provide more detailed info about your application software?
Which KL16 modules you are using with your application?
And do you have any Flash operation within your application?
Ma Hui
884 次查看
tommyp
I flashed a version of the code which stops at POR reset entry and does minimal init to remove any application specific issues.   I'm suspecting that the P&E debugger I'm using is not flashing properly, but since the part is secured, I have no way to confirm beyond the fact the test code is not running.  I'm using a custom trim which the P&E flashes as part of the download process (or should be).   I'm stumped.
884 次查看
Hui_Ma
I would recommend customer to unlock the KL16 chip with Segger J-Link tool.
More detailed info, please check below link:
https://community.nxp.com/thread/439921?commentID=857127#comment-857127
Ma Hui
